Still Not Starting!
Re: Still Not Starting!
Postby cespo500 » Tue Aug 31, 2010 7:52 pm
H1/04 Ignition Switch Start/Run Power Main Fusebox Start/Run Power Black
its in the ign harness and it goes here. Thats prob why its not turning over.
vdubya2
Postby vdubya2 » Tue Aug 31, 2010 8:53 pm
Right just back from the car and had a few developements
Fitted the 16v pump and def more fuel being delivered but still no start
removed relay 30 and 36 but fuel pumps wouldnt work so put relay 30 back in and the pumps worked again still no start
checked power to injectors their is power when turning the engine over but still no start
removed fuel feed line and put the pipe in a clear tub,when i turned ignition on the fuel pumped through
BUT when i turned the engine over the fuel supply ground to a halt!
Is the relay faulty????
Is there a bad earth?????
i dont have the earth lead properly attached to the battery i.e no terminal on it yet just held on with vicegrips would that be a problem?
the other earth wires are secured ok next to the battery on chassis,shoul there be any other earthing on the car?
There is earthing inside the car next to fuse box but all seems ok!!!
'88 mk2 golf gti AAA vr6
25 year anniversary gti tdi
Postby cespo500 » Tue Aug 31, 2010 9:05 pm
thats odd cause obd2 motor dont use a that relay in that slot did you check for that wire?
vdubya2
Postby vdubya2 » Tue Aug 31, 2010 9:19 pm
im going to have to strip the inside of the car to get to the ign loom take it its the bit that plugs into ignition barrel?
Going to check that tommorow after work mate
vdubya2
Postby vdubya2 » Tue Aug 31, 2010 9:26 pm
Dont know about that no 30 relay but on the list i have it has a long list of uses including fuel pump
Postby cespo500 » Tue Aug 31, 2010 11:30 pm
i hear what your saying but if your motor is a obd2 then its not suppose to be there first thing is first get that wire sorted and we will cross the next bridge
sati_007
Legend
Legend
Postby sati_007 » Wed Sep 01, 2010 3:44 pm
Num. Relay Arrangement
1 A/C Relay (13 or 140)
2 Rear Wiper Relay (72)
3 Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
4 Load Reduction Relay (18)
5 Low Coolant Level Control Unit (43)
6 Flashers (21)
7 Headlight Washer (33)
8 Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
9 Seat Belt Warning Control Unit (4 or 29)
9 Radio/Lights Buzzer (36)
10 Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
12 Fuel Pump Relay (80, 67 or 167)
most of your relays are in the worng place , sort them out frist before you mess up your ecu.
vdubya2
Postby vdubya2 » Wed Sep 01, 2010 8:53 pm
oh dear oh dear power run cable is in place the wire that was going nowhere must have been used as a source for something else!
This is where things get annoying,Pump only works with relay 30 in place and if i remove the proper fuel pump relay the damn pumps still work!!!!!!
Where have i gone wrong????
I notice that i dont have the starter interlock relay anywhere in the system its a '97 model im sure do i have to get one and add that in?
Im loosing the will to carry on with this im close but yet so far :(
HELP!
vdubya2
Postby vdubya2 » Wed Sep 01, 2010 8:58 pm
Oh and iv noticed tonight that when i switch on my side lights the wipers and cab fan etc work when i use them and thats with ignition off! unbalievable! :oops: :oops:
vdubya2
Postby vdubya2 » Wed Sep 01, 2010 9:29 pm
This is Obd2 right?
Postby cespo500 » Thu Sep 02, 2010 12:26 am
just get the motor running first. i think the speed senser pins or not in the right place. you gotta see if you have spark then check if the injectors are plusing sorry if i asked again just forgot where we left off.
vdubya2
Postby vdubya2 » Thu Sep 02, 2010 7:44 pm
Getting a spark but when i take the elec plug off the injector and put the light tester on the plug the light just stays on even when turning the engine over!
Was checking power to various plugs and noticed the crank sensor was only getting 1.34v and the white plug was only getting 2.48v.
Assuming the voltage should be 12v im thinking bad earth?
Then i realised i dont have any earth straps from engine or gearbox to chassis should i not have one and where should it go?
Also changed the fuse box got a couple of spare ones but no difference at all.
Users browsing this forum: No registered users and 45 guests
