Vr6 to r32
Kit
Vr6 to r32
Postby Kit » Fri Aug 20, 2010 12:40 pm
Once a VR6 has been installed properly, how much of a mission is it to upgrade to a 3.2L engine?
1984 Audi 80, 1.8 DZ, Sport, Type 81, B2
1990, Golf mk2, 1.6 carb, Driver - V6 track project
Bazmcc
Re: Vr6 to r32
Postby Bazmcc » Fri Aug 20, 2010 1:47 pm
engine loom, ecu, drivers side engine mount, probably clocks too.
It's basically a similar swap again with a bit of custom fabrication thrown in.
B3 AAA VR into a MK2 Driver - Just beginning
Daily Driver - Bora TDI
Kit
Re: Vr6 to r32
Postby Kit » Fri Aug 20, 2010 3:52 pm
Bugger. I was hoping that I could get a nice power-hike if I ever wanted one...
Do all the 24v engines have different wireing-loom/engine mount(s) to the 12v?
And there was me hoping it would just be swapping the ecu and dropping the engine in :shock:
Bazmcc
Re: Vr6 to r32
Postby Bazmcc » Fri Aug 20, 2010 4:02 pm
VR6 is MK2/3 mounts.
R32 is MK4 and is mounted on the chassis legs.
Absolute world of difference in the wiring but you could probably butcher together a loom to make it run.
The ECU is a 121 pin EDC15. Not exactly plug and play to a MK3 VR6 loom. It's also matched to the MK4 clocks and keys.
Kit
Re: Vr6 to r32
Postby Kit » Fri Aug 20, 2010 8:34 pm
Cheers Baz, opened up my eyes a bit :up:
Found this thread for anyone interested in this topic: http://the-corrado.net/forum/viewtopic. ... 54992be7c3
Focus on the ECU side of things
Kit
Re: Vr6 to r32
Postby Kit » Sat Aug 21, 2010 9:28 pm
Just had a thought, is it possible to use a 3.2 bottom end and a 12v head from a 2.9?
I'm guessing not but there's always hope... since the corrado i'm hoping to purchase has a blown bottom end so it'll be rebuilt either way while I use a 2.8.
sati_007
Legend
Legend
Re: Vr6 to r32
Postby sati_007 » Sun Aug 22, 2010 11:27 am
iam not 100% sure about the head swap ...but i read somwere that it has been done but not sure if the engine had bolts holes are in the same place,
United Motorsport
Legend
Legend
Re: Vr6 to r32
Postby United Motorsport » Sun Aug 22, 2010 5:41 pm
Bazmcc wrote:VR6 is MK2/3 mounts.
R32 is MK4 and is mounted on the chassis legs..
The MK3 VR6 mounts will bolt to the R32 Block.
Bazmcc wrote:The ECU is a 121 pin EDC15. Not exactly plug and play to a MK3 VR6 loom. It's also matched to the MK4 clocks and keys.
No its not, Its a ME7 ECU, EDC15 is for Diesel engines. The ECU is matched to the Clock cluster, but this can be turned off.
Kit wrote:Just had a thought, is it possible to use a 3.2 bottom end and a 12v head from a 2.9?
No its not possible.
Kit wrote:Do all the 24v engines have different wireing-loom to the 12v?
Yes they do.
Kit
Re: Vr6 to r32
Postby Kit » Sun Aug 22, 2010 11:04 pm
Thanks for the info, I will give you a ring on Wednesday after I come back from a business trip or perhaps earlier if I get a chance, what hours are you available on that number in your sig?
Bazmcc
Re: Vr6 to r32
Postby Bazmcc » Mon Aug 23, 2010 10:12 am
So there's a set of threaded holes on the back of the R32 block? I've never looked to be honest. That's handy to know.
Sorry got my ECUs mixed up.
benthejettaman
Forum Addict
Forum Addict
Re: Vr6 to r32
Postby benthejettaman » Mon Aug 23, 2010 9:35 pm
look at my build thread bud im doing a conversion from a vr6 to 4motion engine, the 4motion engine is exactly the same swap as the 3.2 r32 conversion
old dubs never die, they just get lower!
vr6nos
Re: Vr6 to r32
Postby vr6nos » Mon Feb 28, 2011 11:19 pm
does a 4motion or r32 or s3 ect rear axle fit onto a mk2 quite easily or is there an easier way to make it a four wheel drive
14.0 in the mk3 vr6 nos... mk2 conversion in the making
Users browsing this forum: No registered users and 41 guests
