Vr6 conversion help for STOCK CLOCKS
Postby 7fingers » Tue Mar 06, 2012 11:11 pm
Hi all I have been doing a mk 2 conversion, it's nearl
Their now just the finishing touchs to finish it off.
I would like to know how I can keep the stock mk 2 clocks
I have been told that I need a convertor!!!!!!??????
If anyone can help would be very much appreciated
I was doing the conversion with my dad he was the
Brains of the out fit but he unfortunately passed away, so
I'm trying my damdest to finish it and get it on the road!
7fingers
Re: Vr6 conversion help for STOCK CLOCKS
Postby cespo500 » Wed Mar 07, 2012 4:37 am
Oh wow sorry to hear about that. To tell you the truth sticking with the mk3 clocks will be your best bet. But if you wanted to use the mk2 clocks you will need the converter. There is a resitistor trick but I am not a fan of it. Also you would need to wire up the vss in back of the clocks so the motor does not cut out in the upper rpms. So as you can see its not a plug and play thing. And you would need a g60 speedo cable.
Resident Expert
Resident Expert
Postby JamesSvr6 » Wed Mar 07, 2012 3:07 pm
x2
I fitted the mk3 clocks because I used an early dizzy engine. It takes a little while to get them to sit right but take your time and they will look factory. Using the mk3 clocks will probably be more reliable in the long run too. It's simpler and less modifying etc to go wrong! Good luck :up:
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
5dr Mk2 Golf VR6-Banded Steels, Respray & Mint Original Interior
Audi A3 Tdi Sport
Honda ATC70 Trike-w/OO Racing 160 engine
JamesSvr6
Dubber
Dubber
Postby 7fingers » Thu Mar 08, 2012 6:38 pm
Thanks guys if you recommend to use the mk 3
Clocks to avoid any play ups with the stock mk2 clocks I'll go that route
Thanks again guys :-)
7fingers
Postby cespo500 » Thu Mar 08, 2012 8:24 pm
is your car obd1 or 2??
Resident Expert
Resident Expert
Return to Conversion help
Users browsing this forum: Google [Bot] and 8 guests
