4 lug with swap
tjpetey83
4 lug with swap
Postby tjpetey83 » Mon Jun 29, 2015 3:15 pm
I am about to pick up a b3 Passat to do the swap from. I am going to change the front motor support bar. To keep the 4 lug and use the 100mm axles and have the 4 lug hubs and spindals what do I need to keep for mounts that are stock and what do I need to swap from the VR6?
Re: 4 lug with swap
Postby cespo500 » Thu Aug 13, 2015 5:05 pm
You will need the rear kframe from a mk3 as the passat wont work. Then transfer all the control arms and sway bar on to it. You can use the front cross member but you will need to cut off the tow hook,
Users browsing this forum: No registered users and 21 guests
