New to Mk2 Vr6 Conversions read this first
NathanVR6
Re: New to Mk2 Vr6 Conversions read this first
Postby NathanVR6 » Mon Aug 20, 2012 9:17 am
What year is the obd1 from? I'm looking at a 1994 plate, M reg VR6 to use as a donor, is there a difference in the systems, what is better, I have the harder task of getting it done as my mk2 is CE1, so excuse the stupid questions! :)
The_GTi_Riddler
Postby The_GTi_Riddler » Tue Aug 21, 2012 11:11 am
NathanVR6 wrote:What year is the obd1 from? I'm looking at a 1994 plate, M reg VR6 to use as a donor, is there a difference in the systems, what is better, I have the harder task of getting it done as my mk2 is CE1, so excuse the stupid questions! :)
1994 will be ODB1 with a Dizzy.
With a Dissy if you want to keep the rev counter then you are going to be easyer converting to CE2 setup and use the mk3 clocks.
If you can find a coilpack engine you can keep the CE1 with some moiforcation to the loom. Took me about 4 weeks to comvert my ODB1 Coilpack loom to be plug and play with my CE1 jetta. added 1 extra cable from the coilpack to the clocks and i have a mk2 clock setup with working Rev counter, MFA and speedo with a 1.3 speedo cable. :up:
rondekker1983
Postby rondekker1983 » Tue Aug 21, 2012 6:26 pm
How can i work the tach of my mk2 cluster. I have a 92 coilpack.
Grtz ron
rondekker1983
Postby rondekker1983 » Tue Aug 21, 2012 6:41 pm
Hello i am from holland. But what means dizzy and coilpack?
Grtz Ron
dubster16v
Dubber
Dubber
Postby dubster16v » Tue Sep 18, 2012 8:20 am
rondekker1983 wrote:Hello i am from holland. But what means dizzy and coilpack?
Grtz Ron
dizzy = distributor, little circular red thing on the right side of the head
coilpack = coils in a pack, rectangular block on the right side of the head
both have the HT leads (spark plug leads) going to them
danielmjpyle
Postby danielmjpyle » Thu Dec 13, 2012 9:14 pm
I have a mk2 vr6 but a previous owner carried out the conversion. Im thinking of reshelling it with a 1.3cl as i think itll be cheaper than having a body shop tackle the rot. Would this be relitivly straight forward as i already have everything on the old shell? I have next to no experiance at this sort of thing...
91wolfie
Postby 91wolfie » Mon May 13, 2013 4:17 pm
Hey,
I am glad i stumbled upon this forum as some as the info has helped. I am planning on doing this swap, And i was looking for opinions. I am Using my 91 Wolfsberg Jetta Coupe as the base, the donor car is a 91 Jetta glx. Will using the GLX be beneficial and provide everything i need or should i scrap it and look for another donor?
Thanks,
Colby
garymk2
Postby garymk2 » Mon Jun 10, 2013 8:34 am
Can anyone shine some light on the mk4 gear shift? Any certain mk4 I need to get the selector from?
And is there any modifications needed?
Thanks
Tatdub83
Postby Tatdub83 » Fri Jul 05, 2013 7:26 am
Hello I've got a mk2 golf running a mk3 gti8v I've just bought a very low mile Sharon with a vr6 and want do swap me n a mate any help on what else I will need to buy to fit it in would be amazing any help would be good as I've asking on a few other sites but never got any where many thanks
Postby cespo500 » Tue Jul 09, 2013 6:49 pm
just an FYI you can not use that harness from the sharon
Tatdub83
Postby Tatdub83 » Tue Jul 09, 2013 6:55 pm
[quote="cespo500"]just an FYI you can not use that harness from the sharon[/quot
Ok why not mate ? So I need a vr6 one ? Any other parts I can't use ?
Postby cespo500 » Wed Jul 10, 2013 1:45 pm
Tatdub83 wrote:
cespo500 wrote:just an FYI you can not use that harness from the sharon[/quot
Because the harness is different, yes you need a vr6 harness.
Users browsing this forum: No registered users and 48 guests
