2.9 Throttle body in 2.8 VR6....
Danieluki
Dubber
Dubber
Postby Danieluki » Sun Apr 25, 2010 12:19 am
Ok ,the last mod I made to my VR6 was as said above ,
One day cleaning my 2.8 TB I saw the ramp this Throttle has just in front of the gate to smooth the air flow in the opening stage....
So I bought a corrado 2.9 TB to test or see what power gains or what happened installed on mine...
The main differences are that 2.9 TB have a bigger body (but exactly the same gate size) , progressive cable actuation (slower initial opening) and dont have this ramp.
some pics to see the differences....(2.8 on the left and 2.9 TB on the right side...)
Yesterday I installed the 2.9 TB and went for a ride , the first impresion was a more responsive throttle feeling (revving the motor parked in the garage, without load)
Ok , but when I ran out to test under load I found the motor fail frequently , when opening the throttle partialy or total... is undriveable...
When I open wide the Throttle the motor stalls suddenly and pull again , stall and pull again.... its like crazy...
I checked the TPS , the MAF and everything seems to be Ok....(I have tried 2 different TPS)
, so I think is a ECU misundertanding problem with the demanding power / Air flow ratio.... and try to correct the differences....
Have anyone tried this before..?
I would like to know what experiences have you about this mod.
Thanks.
vwdom
Forum Addict
Forum Addict
Re: 2.9 Throttle body in 2.8 VR6....
Postby vwdom » Sun Apr 25, 2010 7:21 am
have you reset the tps settings on vagcom as i assume you've removed it to swap the tb's over
atlas grey mk2 vr6 (breaking :( )
06 skoda octavia vrs tfsi
04 black seat leon cupra r 225 (sold)
corrado 16v (when the girlfriend lets me drive it) (sold)
05 honda ctr (when the girlfriend lets me drive it)
suzuki tl1000r
suzuki sv1000s (sold)
1987 yamaha fzr1000
honda crm 250
Danieluki
Dubber
Dubber
Postby Danieluki » Sun Apr 25, 2010 1:21 pm
Yes , I loose the battery positive several minutes while I was reinstalling the throttle....
My VR is an OBD1 so I asume I cant touch any throttle setting through VagCom....
vwdom
Forum Addict
Forum Addict
Postby vwdom » Wed Apr 28, 2010 4:26 pm
i think you can though i've never got my obd1 vr to work on vagcom :?
suzuki tl1000r
1987 yamaha fzr1000
honda crm 250
Danieluki
Dubber
Dubber
Postby Danieluki » Wed Apr 28, 2010 10:20 pm
Hi,
Thanks for your reply but , the problem is solved .... I have been searching the cause and It was a silly thing.
I read the fault codes with the VagCom and this is what I found:
misteriusly I had the Hall connector unpluged...! :? Thats the reason why the motor stalls.
The second fault 00533 is the throttle potentiometer adaptation out of range , disconnecting the battery the ECU reset the old values and get ready for the adaptation.
The third fault 00513 is Engine Speed Sensor (G28) No Signal ,
this is normal on pre '95 models if you scan when the engine is not running
(I have an Vagcom unregistered version and I cant see all the DTCs meaning)
vwdom
Forum Addict
Forum Addict
Postby vwdom » Thu Apr 29, 2010 4:54 pm
mine won't even connect to the ecu :mad:
suzuki tl1000r
1987 yamaha fzr1000
honda crm 250
Postby cespo500 » Thu Apr 29, 2010 5:23 pm
vwdom ill help you if you like its very easy
abfaaa
Postby abfaaa » Tue Feb 22, 2011 11:48 pm
Danieluki wrote:Hi,
But does it run better??
Danieluki
Dubber
Dubber
Postby Danieluki » Thu Oct 06, 2011 6:44 am
Yes... the motor feel more responsive on the throttle in the first stage of the pedal and I can feel how the motor rev much faster without load (parked).... , underload and full open throttle I think is very similar , slightly better maybe (remember the gate is the same size) .
Gibson
The Big Kahoona
The Big Kahoona
Postby Gibson » Thu Oct 06, 2011 10:38 am
all in all a bit pointless then!
holdawayt: "i would walk to Gibsons house again just for a spin in that car!"
Users browsing this forum: Bing [Bot] and 6 guests
