what throttle cable ahhhhh
ukjayz
Postby ukjayz » Wed May 19, 2010 5:53 pm
hi fitted passat pedal box into my mk2 but cant see where to fit a throttle cable i know the mk3 cable ive got out the doner wont fit but not sure wich one to get and how it conects to pedalbox thanks jason
GTi_Phil
Weight Whore
Weight Whore
Re: what throttle cable ahhhhh
Postby GTi_Phil » Fri May 21, 2010 7:16 pm
A corrado VR one or Mk2 one will work. I'm using a 16V mk2 one mate.
matt2.8 wrote:phil was u abit pissed when u wrote this? lol
viewtopic.php?f=21&t=5433&st=0&sk=t&sd=a
viewtopic.php?f=21&t=7963
bennyboi
Postby bennyboi » Mon May 24, 2010 8:11 pm
im using 8v gti one bit tight but loads of grease.
Forum Jedi
Forum Jedi
Postby vdub_1985 » Mon May 24, 2010 8:55 pm
was the 16v cable off a pre or post because i would of thought they are the same but i tryed mine which is pre and it was far too short. I ended up cutting the mk2 16v in half and the vr one and joining them together not the best but still on the look out for one that fits.
GTi_Phil
Weight Whore
Weight Whore
Postby GTi_Phil » Tue May 25, 2010 5:42 pm
Mine was from a 90 mate. I had to run it under the rear plastic rather than over it but it fitted ok.
Forum Jedi
Forum Jedi
Postby vdub_1985 » Tue Sep 14, 2010 9:37 pm
Just to confirm I'm now running a raddo vr cable and fits fine.
Gibson
The Big Kahoona
The Big Kahoona
Postby Gibson » Wed Sep 15, 2010 9:08 am
im running a mk2 16v one.
holdawayt: "i would walk to Gibsons house again just for a spin in that car!"
sati_007
Legend
Legend
Postby sati_007 » Thu Sep 16, 2010 3:55 pm
iam running an 1.3 90spec cable ..bit tight running via the normal mk2 route but fits and works fine
Users browsing this forum: No registered users and 20 guests
