Passat B3 G6o syncro into a mk2
Reference section containing guides and write-ups on the different aspects of the conversion process
autoworkz
Postby autoworkz » Thu Apr 30, 2009 3:08 pm
Hi guys
i am doing a vr mk2 but now i can get my hands on a passat g6o syncro
wanna know if the 4wheel drive system can be adaperted to a mk2????? :(
pls any info will be of great help if it can be done plans are to make it a mk2 vr awd... :up:
misteralz
Re: Passat B3 G6o syncro into a mk2
Postby misteralz » Thu Apr 30, 2009 3:48 pm
Good luck finding one of those... :whistle:
autoworkz
Postby autoworkz » Thu Apr 30, 2009 4:16 pm
misteralz
I dont think u understood right i said that i can get 1 meaning i have gone to go see it(passat b3 G60 syncro)
and have driven it allready.My question is still can the conversion be done?is it worth me buying it
misteralz
Postby misteralz » Thu Apr 30, 2009 4:29 pm
Seems a shame to rip a rare car like that to bits unless it's terminally rotten. But yes, pretty much everything will fit with only slight modification. It's the bolting the VR up to the G60 'box bit that'll be your main stumbling block.
autoworkz
Postby autoworkz » Thu Apr 30, 2009 4:35 pm
Oh that is great news mate thanks for that info so it can be done :-D
Never new that it was such a rare car :oops:
ok as for the vr to the g60 box :( big mods or not???)
D16vGTi
Forum Overlord
Forum Overlord
Postby D16vGTi » Thu Apr 30, 2009 4:40 pm
You'll need a vr6 syncro gearbox and possibly the rear diff depending on what power you are expecting to run :up:
misteralz
Postby misteralz » Thu Apr 30, 2009 4:55 pm
Yep - and it should fit into the Passat's rear cradle. The axle should be a straight bolt-in swap, the rear floor and tank may well be, too, although I suspect the rear floor will need some trimming to fit a mk2.
autoworkz
Postby autoworkz » Thu Apr 30, 2009 5:01 pm
nice 1 guys thanks for all the info
going to try hunt down a vr box as for the power it will
be a standard vr for now :up: :up:
D16vGTi
Forum Overlord
Forum Overlord
Postby D16vGTi » Thu Apr 30, 2009 5:52 pm
Try ebay.de :up:
GTi_Phil
Weight Whore
Weight Whore
Postby GTi_Phil » Fri May 01, 2009 5:41 pm
If this does go ahead be sure to put a project thread up, would be an interesting build to see. :up:
matt2.8 wrote:phil was u abit pissed when u wrote this? lol
viewtopic.php?f=21&t=5433&st=0&sk=t&sd=a
viewtopic.php?f=21&t=7963
Return to “How-To's & FAQs”
Users browsing this forum: No registered users and 3 guests
