ECU code info
admin
Site Admin
Site Admin
ECU code info
Postby admin » Wed May 10, 2006 12:43 pm
RETRIEVING CODES (DIGIFANT System)
1. Turn the ignition ON. Connect the black end of the jumper cable to the black diagnostic connector in center console under shift boot. Connect the white end of the jumper to the white diagnostic connector.
2. After five seconds the OBD CHECK light should begin to flash. Remove the jumper, but do not turn off the ignition. Record the flashes.
3. When code 4444 or 0000 appears, then either turn off the ignition or reinstall the jumper to end code readout.
Possible wiring faults should be checked and corrected before replacing a suspected component. Once the fault is corrected, the permanent fault memory should be erased as described below.
CLEARING CODES
1. Make sure the ignition is OFF. Connect the jumper cable as described in RETRIEVING CODES. Turn the ignition ON.
2. After 5 seconds remove the jumper cable. The OBD light should flash 4444. Turn the ignition Off or reinstall the jumper cable to end the procedure.
RESETTING ECU
The Digifant I ECU must be reset to its reference setting after certain conditions or repairs as follows:
· The blue coolant temperature sensor connector has been disconnected with the engine running
· The following components have been replaced:
o Digifant ECU
o Air Flow Sensor
o Throttle Valve Potentiometer
o Throttle Valve Body
When resetting the ECU, the engine must be at normal operating temperature, all electrical accessories must be Off, the idle stabilization system must be okay, and the exhaust system must be leak-free.
1. With the engine off, disconnect the crankcase ventilation hose from the emission control valve atop the valve cover, then plug the hose. Start the engine and let it idle. Disconnect the blue coolant temperature sensor harness connector.
2. Let the engine idle for one minute, then reconnect the harness connector. CAUTION: DO NOT reconnect the coolant temperature sensor harness connects, while the radiator cooling fan is running.
3. Turn the engine off and reconnect the crankcase ventilation hose. Erase the OBD fault memory.
NOTE: Disconnecting the coolant temperature sensor with the engine running generates fault code 2312.
Retrieving Codes (Bosch Motronic CIS-E)
The Bosch Motronic system (CIS-E) requires a scanner to retrieve and clear the trouble codes.
MIL
VAG
Fault
1231
00281
VSS Signal
2111
00513
ESS Defective
2113
00515
Hall Sensor Rotor
2212
00518
TVP Circuit
2312
00522
ECT Sender
2141
00535
Knock Regulation
2142
00524
Knock Sensor
2342
00525
O2S Probe
2412
00527
IAT Sender
2234
00532
Battery Voltage Too High/Low
2231
00533
Idle Regulation Adaptation
2341
00537
O2S Probe Heater
2144
00540
KS No. 2
2214
00543
Maximum Engine Speed Exceeded
2314
00545
Engine/Transaxle Electrical Connection Short To Ground
2324
00553
Air Volume Meter
2413
00561
Fuel Pressure Improper
2411
00585
Temperature Sensor In EGR Valve
00586
EGR Valve
01025
OBD Lamp
4332
01242
Loose Terminal To Output Components Or Control Unit
4343
01247
Carbon Canister System Solenoid Valve No. 1
4411
01249
Injector No. 1 Cyl.
4412
01250
Injector No. 2 Cyl.
4413
01251
Injector No. 3 Cyl.
4414
01252
Injector No. 4 Cyl.
4421
01253
Injector No. 5 Cyl.
4422
01254
Injector No. 6 Cyl.
4431
01257
Idle Speed Stabilizer Valve
4433
01259
Fuel Pump Relay
4312
01265
EGR Valve
1111
65535
ECM
Return to “Engine”
Users browsing this forum: No registered users and 12 guests
