Deezys 88 gti vr6 swap
it'll be finnished one day..
deezy
Re: Deezys 88 gti vr6 swap
Postby deezy » Fri Dec 27, 2013 8:15 pm
http://youtu.be/cP67OYiWa8M
Sent from my iPad using Tapatalk
deezy
Postby deezy » Fri Dec 27, 2013 8:16 pm
deezy
Postby deezy » Fri Mar 28, 2014 5:57 pm
So. Its been a while. I have been slowly doing things. Repairs and such. I broke two piston ring landing a few weeks ago and I'm in the process of rebuilding the block. I've ordered new struts. Installed a wotbox with 2-step and launch control. I'm currently interested in trading my c2 stage 4 chip with promaf and wot box for a lugtronic PNP ecu.
Sent from my XT912 using Tapatalk
deezy
Postby deezy » Mon Mar 31, 2014 12:35 am
Image Image Image
deezy
Postby deezy » Thu May 29, 2014 1:44 am
I don't know if anyone still follows but... I just installed a lugtronic stand alone ecu with wideband and boost control... Day and night difference vs the stage 4 c2 chip and promaf. I have power in between gears and everything.
deezy
Postby deezy » Tue Mar 22, 2016 3:35 pm
New wheels
15x7 Zender Sport 4x100
Forum Jedi
Forum Jedi
Postby vdub_1985 » Mon Jul 11, 2016 7:25 am
That's something I wish I did on mine looking back now. I had it all mapped to run etc but no saved maps like that and the power was nice but just got alittle boring as I couldn't always put it down.
deezy
Postby deezy » Wed Apr 19, 2017 9:51 pm
I need to update, I broke a valve and said valve decided to go straight into my turbo causing havoc.
Well i fixed it, New turbo Borg warner s366 is a beast!
I also put two Rota slipstream wheels up front wrapped in some 235-50-15 Mickey thompson Drag radials.
needless to say i stripped 3rd gear on my 4th run.
Plans are
Install a cage
5 speed dog box
Bigger injectors
axles
better clutch
still running a stock motor block except for
arp head studs, arp rod bearings
heavy duty valve springs and titanium retainers.
schrick 276 camshafts
9:1 compression spacer.
If you have instagram follow me @vr6deezy
i also have a jetta mk2 vr6 turbo now as well
Return to “Project diaries”
Users browsing this forum: No registered users and 28 guests
